PROBLEM
Running a geoprocessing tool using a Python script fails and returns the 000725 error
First Published: April 8, 2022
Last Published: April 8, 2022
Attempting to run a geoprocessing tool using a Python script fails with the following error message returned:
Error:
000725: <value>: Dataset <value> already exists.
Cause
The 'Allow geoprocessing tools to overwrite existing datasets' option is disabled on the Options tab. If this option is disabled, existing layers with the same name as the output layer may cause the error message to be returned. This is because the Python interpreter is unable to prompt a pop-up window confirming to overwrite the file with the same name.
Solution or Workaround
Enable the 'Allow geoprocessing tools to overwrite existing datasets' option
  1. In ArcGIS Pro, navigate to Project > Options > Geoprocessing.
  2. On the Geoprocessing tab, check the Allow geoprocessing tools to overwrite existing datasets option.
The Options pane with the Geoprocessing tab
  1. Save the project and restart ArcGIS Pro.
Set 'overwriteOutput' to true
If the 'Allow geoprocessing tools to overwrite existing datasets' option must be disabled, add the following ArcPy script after importing the necessary modules:
arcpy.env.overwriteOutput = True
Use a different name for the output layer
When specifying the output name in the Output parameter, use a name that is different from the existing layers.
Article ID: 000027490
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
