PROBLEM
Republishing a metadata document doesn't replace the original document
When republishing an existing metadata document to a metadata service, an additional copy of the document is added to the service when the user does not have write access to the source metadata document (XML file).
Cause
Every metadata document published to a metadata service is assigned a unique ID that is written to the source metadata document when it is first published. If the user does not have write access to the source metadata document, the ID can not be written to it. As a result, when the user republishes the same metadata document, the metadata service can not compare the ID with the IDs of documents already published; the metadata service assumes the document is a new metadata document.
Solution or Workaround
Ensure the user has write access to the source metadata document so the metadata service can assign it a unique ID. When the service republishes the document, it will replace the existing document.
Article ID:000005254
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
