PROBLEM
Registration Wizard crashes while registering single use ArcGIS products
The Registration Wizard crashes while attempting to register a single use ArcGIS application or extension.
Cause
The path to the .esu9 license file is too long. The ArcGIS Registration Wizard accepts license files, only if the path to the file is less than 110 characters.
Solution or Workaround
Place the .esu9 single use license file in a location with a file path of less than 110 characters (e.g., 'C:\ArcGIS License File'), and run the Registration Wizard again.
    Article ID:000009807
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
