PROBLEM
REGIONPOLY creates an output coverage that does not have labels
Using REGIONPOLY to convert a region coverage to a polygon coverage will result in an output coverage that does not have labels.
Cause
The input coverage does not have labels(possibly from a shapefile to coverage conversion), and an {out_table} is not specified.
Solution or Workaround
Use CREATELABELS, either before or after performing the REGIONPOLY command, to ensure that the output polygon coverage contains labels.
Article ID:000003770
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
