PROBLEM
Rasters with read-only permission retain georeferencing after .aux and world files are removed
A read-only image is registered and has the georeferencing updated. When ArcMap is closed and the .aux and world files are removed, the image retains the georeferencing when subsequently displayed in ArcMap.
Cause
For read-only rasters, the georeferencing and other information (except the world file) get written to the raster proxy location.
Solution or Workaround
To remove the georeferencing for the read-only image, it is necessary you delete the .aux and .uai (unrestricted access image) files for the raster from the rasterproxies folder.
Article ID:000003251
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
