PROBLEM
Raster values greater than the last class break display with the symbology of the last class
A raster is added to ArcMap and symbolized using the Classified renderer. By clicking the Classify button on the Classify symbology tab, you can specify the class breaks. Even if you decrease the top break value, dataset values above this are drawn with the symbol for the top class.
Cause
This is a known issue with ArcGIS 8.1.
Solution or Workaround
When specifying a class break that is lower than the maximum value of the raster, use the Exclude functionality within the Classified renderer Classify dialog box to exclude values higher than this class break. This will cause all values higher than the value specified for the class break to not draw.
Article ID:000003456
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
