PROBLEM
Raster borders are visible when added directly to a map in ArcGIS Pro
Last Published: April 28, 2021
In ArcGIS Pro, rasters contain individual bands which are combined to create a natural looking image on a map. In certain instances, when raster datasets are added from a folder to a map directly, the borders between the rasters are visible, as shown in the image below.
A border is visible between the rasters added to the map from the Contents pane.
Cause
The rasters added to the map have differing minimum and maximum values. The minimum and maximum values are used to standardize the appearance of multiple rasters for comparison. When the values are not scaled to optimize the color transition between the rasters, a visible border is displayed.
Solution or Workaround
Follow the workflow below to resolve the issue using the Add Rasters To Mosaic Dataset tool.
  1. Create a mosaic dataset.
    1. In ArcGIS Pro, in the Catalog pane, under the Databases folder, right-click the desired database. Click New > Mosaic Dataset. In this example, the database is CheckMosaicDataset.gdb.
Open the Create Mosaic Dataset tool by navigating to the database in the Databases folder in the Catalog pane, right-click the database, navigate to New and click Mosaic Dataset.
  1. In the Create Mosaic Dataset tool pane, on the Parameters tab, for Mosaic Dataset Name, type a name for the dataset. In this example, the name for the mosaic dataset is MinMax_Article.
  2. Click Run.
The Create Mosaic Dataset tool pane, on the Parameters tab, shows the settings available to run the tool. Type in a name in the box for the Mosaic Dataset Name section. Click Run at the bottom-right side of the pane to run the Create Mosaic Dataset tool.
  1. Add the rasters to the mosaic dataset.
    1. In the Catalog pane, right-click the newly created mosaic dataset. Click Add Rasters....
Open the Add Rasters To Mosaic Dataset tool by right-clicking the newly created mosaic dataset in the Catalog pane, and click Add Rasters....
  1. In the Add Rasters To Mosaic Dataset tool pane, on the Parameters tab, select the appropriate raster type from the Raster Type drop-down list.
  2. For Input Data, click the Browse The Browse icon symbol. icon to select the rasters.
  3. Expand Raster Processing. Check the Calculate Statistics box.
  4. Click Run.
In the Add Rasters To Mosaic Dataset tool pane, for Input Data, click the Browse icon on the right side of the box to select the raster data from the desktop. Enable the Calculate Statistics option by expanding Raster Processing, and check the Calculate Statistics box. Click Run at the bottom-right side of the pane to run the tool.
The minimum and maximum values of the rasters are standardized, and the borders are not visible as shown in the image below.
The borders between the rasters are not visible, the rasters appear seamless.
Article ID: 000025128
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
