PROBLEM
Python script fails to run when using port 6443
Attempts to run a Python script to perform ArcGIS Server processes (for instance the process described in Example: Write properties of all services to a CSV file) fail after changing port 6080 to port 6443 in the script. The following error message may be returned as well:
Error:
Error while fetching tokens from admin URL. Please check the URL and try again.
Cause
The ArcGIS Server protocol is set to 'HTTP Only'. ArcGIS Server uses certain ports to communicate with machines, for example, HTTP port 6080 and HTTPS port 6443. Refer to ArcGIS Enterprise: Ports used by ArcGIS Server for more information.
Solution or Workaround
Change the ArcGIS Server REST endpoint protocol to 'HTTP and HTTPS'
  1. Navigate to the ArcGIS Server Administrator Directory login page, and log in using a primary site administrator account, for example:
https://machine.domain.com:6080/arcgis/admin
  1. Click security > config > update.
The ArcGIS Server Administrator Directory Update page to change the security protocol.
  1. Change the protocol setting from HTTP Only to HTTP and HTTPS.
  2. Click Update, and wait until the page reloads.
The Security Configuration section to change the security protocol from to HTTP and HTTPS.
Article ID: 000026418
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
