PROBLEM
Python Exception error "bad magic number in 'requests.packages': b'\x03\xf3"
First Published: May 25, 2021
Last Published: April 16, 2024
In some scenarios, such as calling a Data Interoperability Spatial ETL Tool from a Python script, the following error is returned:
Error:
The "magic number" comes from UNIX-type systems where the first few bytes of a file held a marker indicating the file type. Python puts a similar marker into its pyc files when it creates them. The Python interpreter ensures that this number is correct when loading the file.
ArcMap is in Mature support and will be retired March 1, 2026. There are no plans for future releases of ArcMap, and it is recommended that you migrate to ArcGIS Pro. See Migrate from ArcMap to ArcGIS Pro for more information.
Cause
Anything that damages this magic number will cause the error. This includes editing the .pyc file or trying to run a .pyc file from a different version of Python (usually later) than your interpreter.
Solution or Workaround
  1. If the issue is with your .pyc files, delete them and let the interpreter re-compile the .py files. On UNIX-type systems, that could be something as simple as:
rm *.pyc
or:
find . -name '*.pyc' -delet
  1. Uninstall the Data Interoperability extension.
  2. Reinstall the correct version of Python.
  3. Reinstall Data Interoperability.
Article ID: 000025627
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
