PROBLEM
Publishing cached services with custom tiling scheme creates empty tiles
Last Published: May 6, 2024
After publishing a cached map service or imagery service with a custom tiling scheme, only some of the expected level of details are created on the ArcGIS Server cache directory.
  • Using the Manage Map Server Cache Tiles tool to re-create the empty tiles doesn't resolve the issue.
  • The service Caching status on ArcGIS Server Manager is incomplete and doesn't change to 100%.
Cause
The tiling scheme file is generated using the Generate Tile Cache Tiling Scheme geoprocessing tool.
Solution or Workaround
For publishing cached services with a custom tiling scheme, use the Generate Map Server Cache Tiling Scheme tool to generate the tiling scheme file. The Generate Tile Cache Tiling Scheme tool is intended to be used when the cache is generated locally on the client machine. Using the tiling scheme file generated by this tool for publishing cached services to ArcGIS Enterprise can cause unexpected behavior.
Article ID: 000031095
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
