PROBLEM
Properly accessing INFO files and records for SDTS data
Solution or Workaround
Summary
The data does not link properly and the item values are not as expected when using a relate or JOINITEM between the FAT's and INFO tables for converted SDTS files.
{BOLDCause
The SDTS/DLG JOIN file has a 1:n relationship to records in the FAT.
Solution
The example below illustrates SDTS files being accessed for arc data. The example is basically the same for polygon features as well.
Let's say the SDTS/dlg roads coverage name is TRST011. There are 2 sets of attributes for each line feature. Attributes will be in files TRST011.ARDM and TRST011.ARDF.
The TRST011.AJOIN has two records for each TRST011-id. Each record stores the name of the file, referenced by extension (ARDM) and the record number in that file that contains the features attributes.
TRST011.AJOIN
Record TRST012-ID MODN_NAME MODN_ID
1 1 ARDF 6707
2 1 ARDM 1877
Code:
Arcplot: items TRST011.ardm info
COLUMN ITEM NAME WIDTH OUTPUT TYPE N.DEC ALTERNATE NAME
INDEXED?
1 MODN_ID 6 6 I - -
7 ROUTE_NUMBER 7 7 C - -
14 ROUTE_TYPE 9 9 C - -
We want to get at the route numbers for the roads features. We can do this with the keyfile option, like this:
Code:
Arcplot: mapext TRST011
Arcplot: res TRST011.ajoin INFO modn_name cn 'ARDM'
Arcplot: res TRST011 arcs keyfile TRST011.ajoin TRST011-id
Arcplot: relate restore TRST011.rel
Arcplot: list TRST011 arcs ajoin//modn_name
Arcplot: list TRST011 arcs ajoin//ardm//route_number
You'll get this:
Record  ajoin//ardm//route_number
1 I 40
2 I 40
3 I 40
4 I 40
Article ID:000001398
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
