PROBLEM
Projecting with COMMAND TOOLS creates a corrupted coverage
Solution or Workaround
Problem
When using the PROJECT COVERAGE tool to project a coverage the resulting coverage is corrupted.
Cause
When a DENSIFY value of 0 is used in the input projection parameters, PROJECT creates a corrupted coverage. On the Windows NT platform, the coverage will be split into many arcs forming a rectangular box that is far outside of the original coverage's boundary. On UNIX, the coverage will have far more arcs with small gaps dispersed throughout them.
Solution
Make the following changes to the prj_driver.aml in the $ARCHOME/arctools/projectlib directory.
a) Change line 595 from:
&if ^ [null [value .prj_driver$p_densify]] &then
to:
&if ^ [null [value .prj_driver$p_densify]] and [value .prj_driver$p_densify]_
^= 0_ &then
b) Change line 607 from:
&if ^ [null [value .prj_driver$p_generalize]] &then
to:
&if ^ [null [value .prj_driver$p_generalize]] and [value
.prj_driver$p_generalize]_ ^= 0_ &then
This may apply to version 7.0.4 of ArcTools, and earlier versions.
Article ID:000001333
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
