PROBLEM
Programmatically deleting a geometric network, then deleting Dataset in Treeview, will cause ArcCatalog to fatal
Programmtically deleting a geometric network in ArcCatalog and then deleting the network's feature dataset, will cause ArcCatalog to fatal.
Cause
This is a known issue.
Solution or Workaround
There are two workarounds for this problem:
  • Do not delete the feature dataset following this operation. Close and re-start ArcCatalog to delete the dataset.
  • Delete the network using IGxObjectEdit:Delete instead of Dataset:Delete. In ArcCatalog, get a reference to the selected object from IGxApplication:SelectedObject and QI to IGxObjectEdit
Article ID:000003781
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
