PROBLEM
Profiling a 3D line theme results in discontinuous lines in the profile graph
When profiling a continuous line across a 3D surface using the Profile Graph tool in the layout, the tool creates a graph of several lines instead of the expected single, continuous profile line.
Cause
When profiling a PolylineZ feature theme, the profiler will create a profile line for each selected PolylineZ, or for all features if none is selected. In the case of 3D graphics, the tool will profile each selected graphic separately, or it will be inactive if none is selected.
Solution or Workaround
  • Draw a single, continuous graphic across the surface.
  • Merge the features of your theme into a single feature.
    Warning:
    Be wary of lines that come close but don't actually connect. If the PolylineZ is a single feature but not truly contiguous, the profile line in the graph will have gaps corresponding to the gaps in the PolylineZ.
    For more information search the ArcView online help index for 'Merging line features' and 'Interactively creating 3D point, line, and polygon features'.
Article ID:000003508
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
