PROBLEM
Metadata created using the DOCUMENT command in ArcInfo Workstation is not be reflected in ArcCatalog.
ArcCatalog is not able to get the history out of a coverage's log file and insert it into the metadata.
You should do this periodically since the metadata remains static
Article ID:000002537
Get help from ArcGIS experts
Download the Esri Support App
