PROBLEM
Problems with street intersections when geocoding with Avenue
Solution or Workaround
Errors occur with street intersections when geocoding with Avenue.
Answer:
Ensure that when setting up the initial geocoding objects, 'Allow Intersections' on both the MatchKey and MatchCase objects just after creating them. Also, use the 'us_addr.stn' standardization rules when making the MatchKey, but then use the 'us_intsc.stn' standardization rules when using AllowIntersections on that new MatchKey object. In addition, make sure that the intersection delimiter noted in the third line below is the same as what the event addresses are using. It is possible to change this line or change the data to make them the same.
aMatchSource = theMatchTheme.GetMatchSource
aMatchKey = MatchKey.Make("us_addr.stn")
aMatchKey.AllowIntersections("us_intsc.stn"," & ")
aMatchCase = MatchCase.Make(aMatchSource, aMatchKey)
aMatchCase.AllowIntersections(aMatchSource, aMatchKey)
aMatchPref = MatchPref.Make
Notes:
Intersection geocoding using Avenue is only possible with version 2.0d or higher.
Article ID:000001510
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
