PROBLEM
Problems setting up ArcIMS with a proxy server
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
User is having problems getting ArcIMS to work with a proxy server. Followed all the instructions in the ArcIMS Installation Guide or ArcIMS Help FAQ, and ArcIMS Help System Administration, Administering property files section, without success.
Cause
We have found a case where the Servlet Engine needed a virtual directory so the Servlet Engine could be contacted by the proxy server.
Solution or Workaround
Creating a virtual directory called servlet to the Servlet Engine may be the solution if problems persist with ArcIMS and the proxy server.
    Article ID:000003478
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
