PROBLEM
Printed layout files do not match layouts in ArcGIS Pro
First Published: September 2, 2022
Last Published: September 2, 2022
When printing layouts using the Print Layout button, the printed layout files do not display according to the layout in ArcGIS Pro. In some instances, the printed files display blank pages, or the map frame and other layout elements are cropped.
The image below shows the layout in ArcGIS Pro.
The desired layout in ArcGIS Pro.
The image below shows the layout in the printed file which does not match the layout in ArcGIS Pro.
The layout in the printed file which does not match the layout in ArcGIS Pro.
Cause
This is by design if the map frame is activated when printing the layout in ArcGIS Pro. The rest of the layout is not available until the Close Activation The Close Activation button. button is clicked on the Layout tab.
Solution or Workaround
The following steps describe how to deactive the map frame.
  1. In ArcGIS Pro, on the top ribbon, click the Layout tab > Close Activation.
Alternatively, click the Close activated map frame icon to deactivate the map frame.
The Close activated map frame icon.
  1. Click the Share tab > Print Layout. Configure the printing settings and print the layout.
The image below shows the layout settings in the printed file match the layout in ArcGIS Pro.
The layout in the printed file match the layout in ArcGIS Pro.
Alternatively, export the layout by clicking the Share tab and select the Export Layout button to export the layout before printing it.
The Export Layout button.
Article ID: 000028306
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
