PROBLEM
Preview doesn't update when changing a layer's symbology
The Preview tab doesn't show changes to a layer's symbology.
Cause
The Contents tab is not selected.
Solution or Workaround
  • When changing the properties for a layer file (.lyr) in ArcCatalog, make sure the Contents tab is selected. This allows the layer file's image to be updated properly when displayed in the Preview tab.
  • If the Preview tab is selected, and you make changes to some layer properties, the preview image will not updated automatically. In this case, select the Contents tab, then go back to the Preview tab to see the correct image.
Article ID:000003176
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
