PROBLEM
Pop-ups display the same attribute information of all map features in ArcGIS Pro
First Published: June 18, 2025
Last Published: June 18, 2025
In ArcGIS Pro, when selecting a feature on the map, the pop-up displays the attribute information of all the features present on the map rather than the individual feature selected.
Cause
The data is derived from a shapefile. Shapefiles have more limitations compared to feature classes and do not support advanced capabilities found in geodatabases. Refer to ArcGIS Pro: Limitations of shapefiles for more information.
Solution or Workaround
To resolve the issue, export the shapefile to a geodatabase feature class from the Catalog pane or the Contents pane in ArcGIS Pro. Refer to ArcGIS Pro: Export a shapefile for instructions.
Article ID: 000035140
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
