PROBLEM
In ArcGIS Instant Apps, pop-ups display information based on either an input address or a click on the map using the geolocation service. The image below shows the pop-ups are not displayed when clicking features in the Zone Lookup template.
Depending on the cause, the following workarounds are applicable.
In the Zone Lookup template, the search results can be refined by two search sources, from layers in the map or locators from the organization. By default, ArcGIS World Geocoding Service is configured as the search source of a map in ArcGIS Instant Apps. Refer to ArcGIS Blog: Refining search capabilities in your Configurable Apps for more information. Follow the workaround below to add the search source to the map. In this example, ArcGIS World Geocoding Service is added as the search source.
The image below shows the pop-up displayed when clicking a feature.
In the Zone Lookup template, select ‘For a zone’ as the search type to display all the features’ pop-ups for all the layers in the map.
Article ID: 000032320
Get help from ArcGIS experts
Start chatting now
