PROBLEM
Polygon fills bleed over or fill entire page when printing or exporting.
Data layer with the polygon fill has broken geometry, which is causing the fill symbology to bleed when printed or exported.
Repair Geometry overwrites the existing data, so it is recommended to make a copy of the original data and run the Repair Geometry on the copy. If you make a copy, be sure to change of source of the layer in ArcMap to the new repaired copy before printing or exporting again.
Article ID:000008800
Get help from ArcGIS experts
Download the Esri Support App
