PROBLEM
Point features in a feature service published from ArcGIS Desktop display in incorrect locations in Map Viewer
Last Published: July 13, 2020
In ArcGIS Online, point features in a feature service published from ArcGIS Desktop display in incorrect locations when viewed in Map Viewer.
Cause
The following are possible causes:
  • The spatial index of the feature layer is not properly rebuilt when published from ArcGIS Desktop.
  • The data is defined in a coordinate system other than the WGS 1984 Web Mercator (Auxiliary Sphere) coordinate system. This is the default coordinate system of basemaps in ArcGIS Online. When data is defined in a different coordinate system, the point features are displayed in incorrect locations on the basemap. Refer to ArcGIS Online: FAQ – What is the coordinate system of the web maps in Map Viewer, and can I change it? for more information.
Solution or Workaround
Rebuild the spatial indexes of the feature class
  1. In ArcGIS Online, navigate to the Content tab.
  2. Click the hosted feature layer to open the hosted feature layer's item page.
  3. On the Settings tab, check the Enable Editing option.
  4. Click Rebuild Indexes under the Manage Spatial Indexes section.
  5. Check the feature layers checkboxes to rebuild spatial indexes for the layers, and click Rebuild.
Image showing the Rebuild Indexes window
Data is defined with a coordinate system other than the WGS 1984 Web Mercator (Auxiliary Sphere)
There are two workarounds related to this cause.
Article ID: 000023325
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
