PROBLEM
Personal geodatabase does not show any object classes
No object classes appear to exist when browsing a personal geodatabase using ArcCatalog or ArcMap.
Cause
Possible data corruption.
Solution or Workaround
Compacting the geodatabase will copy all tables in the underlying database into a new database eliminating corruption.
  1. Open ArcCatalog.
  2. Navigate to the personal geodatabase.
  3. Right-Click the personal geodatabase and select Compact Database.
    Depending on the size of the geodatabase, this make take several minutes.
Article ID:000007107
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
