PROBLEM
Patches and labels overlap in an ArcGIS Pro legend
Last Published: January 7, 2021
In ArcGIS Pro, when editing items in the legend, the patches overlap with their labels.
Image of the patches overlap with their labels in a legend
Cause
The problem occurs when the default symbol size of a feature layer is modified, causing the patch to overlap with the label in the legend.
Solution or Workaround
To resolve this issue, choose one of the methods provided below.
Configure the width and height of the patches
  1. In ArcGIS Pro, click the Layout tab to activate the layout view. The tab color turns blue.
Image of the active layout view
  1. In the Contents pane, right-click Legend, and click Properties.
Image of the Legend context menu
  1. In the Element pane, on the Options tab, expand the Legend Items node, and click Show properties….
Image of the Element pane context menu
  1. In the [multiple items] pane, expand the Sizing node, and configure Patch width and Patch height by clicking the Increment or Decrement Image of the increment and decrement arrow arrow.
Image of the [multiple items] pane
Configure the spacing between the patches and labels
  1. In the Element pane, click the Legend Arrangement Options Image of Legend Arrangement Options icon tab, and expand the Spacing node.
Image of the Element pane, in the Legend Arrangement Options
  1. Change the value for Patches and text to configure the spacing between the patches and labels. Refer to ArcGIS Pro: Change the legend's appearance for more information.
Image of Spacing configuration
The image below shows the patches and labels no longer overlap in the ArcGIS Pro legend.
Image of the patches and labels are no longer overlapping in the ArcGIS Pro legend
Article ID: 000024819
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
