PROBLEM
Paste does not copy attributes to target feature class
The Paste command fails to copy attributes into the target layer.
Cause
If the feature is pasted into a feature class that is different than its source, the Paste command will copy the feature's geometry but not its attribtues.
Solution or Workaround
Use the Load Objects command to copy and paste the geometry and attributes of features between feature classes.
Article ID:000003581
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
