PROBLEM
Overlapping labels are still drawn even when they are turned off
After setting a layer's labeling properties to not show overlapping labels, sometimes the overlapping labels are still displayed.
Cause
There are several scenarios for which this may occur:
· You are using a conflict detection buffer tolerance.
· You are using a text symbol with a halo mask.
· You are projecting the map such that it is wrapped around the horizon (example, customized World Robinson).
Solution or Workaround
If possible, avoid the mentioned scenarios, or convert the labels to annotation and edit their position.
Article ID:000003107
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
