PROBLEM
When using the Make Image Server Layer tool in ArcMap, if the number of rows and columns for an image server layer exceeds the default values, the tool returns the following warning message:
Warning: 000950: Output raster exceeds the size limitation (rows: <value> and columns: <value>) defined on the image server. Please input a smaller extent.
The Make Image Server Layer tool cannot produce an image server layer larger than the size specified in the image service properties. It can only access data that falls within the extent defined in the image service properties.
There are two solutions to this issue.
The instructions provided describe how to change the mosaic dataset and the image service properties.
Note: Using the entire extent of a large image service can cause performance issues on the server end. This is because at any given time, thousands of users are accessing the raw data for analysis or downloading raw data. So an increase in the number of rows and columns increases the time it takes to process the mosaicked image, and affects the performance of the server.
Article ID: 000011900
Get help from ArcGIS experts
Start chatting now
