PROBLEM
The Shortest Path function in Spatial Analyst, when using the output distance and direction rasters generated by the Straight Line Distance function, returns the message:
"Operation Failed"
The Shortest Path function is designed to work using the output distance and direction rasters generated by the Cost Weighted Distance function, not by the Straight Line Distance function.
Generate distance and direction rasters with the Cost Weighted distance function. Use these as the inputs for the Shortest Path function.
Article ID:000003318
Get help from ArcGIS experts
Download the Esri Support App
