PROBLEM
Operation Failed [loading raster]
Attempting to load a raster with a data depth of two bits fails with this error message:“Operation Failed”
Cause
This is a known issue.
Solution or Workaround
  1. Write a script to save the raster dataset to another data type, such as 4-bit, using Raster::SaveAs.
  2. Load the resulting output raster dataset into the database.
Article ID:000003155
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
