PROBLEM
On Windows 2000 with IIS5, after going through the ArcIMS installation I get an error saying that I don't have administrator privileges
On Windows 2000 with IIS 5.0, after going through the ArcIMS installation I get an error saying that I don't have administrator privileges. I then get an error message that ArcIMS cannot be uninstalled.
Solution or Workaround
This problem occurs occasionally on Windows 2000 even if you have administrator priviledges.
  1. Do a manual uninstall of ArcIMS 3.1 from Add/Remove Programs in the Control Panel.
  2. Next, log out and then log back in.
    You should be able to install ArcIMS 3.1 after logging out.
Article ID:000003424
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
