PROBLEM
Numeric fields not available using Statistics from the Select widget in ArcGIS Experience Builder
Last Published: August 30, 2024
In ArcGIS Experience Builder, the Select widget is designed to enable users to interactively select features from a map or a scene. Once features are selected, the widget allows for further actions such as filtering, displaying details, generating statistics, or triggering other widgets in the application. However, when generating statistics using the Statistics data action, not all numeric fields are displayed, as shown in the image below.
Numeric fields are not available when using the Statistics data action from the Select widget
Cause
This is by design, as only the ObjectID field is used in the Select widget.
Solution or Workaround
Add a Table widget to the experience to display the other numeric fields.
  1. Open the ArcGIS Experience Builder project and navigate to the Insert widget panel.
  2. Under Data centric, drag and drop the Table widget to a desired position in the experience.
  3. In the Table widget's settings, under the Content tab, click New sheet to open the Sheet configuration panel.
  4. Under Data, click Select data and select the feature layer containing the numeric fields. If necessary, click Add new data to add a new feature layer from ArcGIS Online.
  5. On the builder toolbar, click Live view.
  6. Navigate to the Select widget and choose an interactive selection tool.
  7. Draw the desired features in the Map widget to select the features.
  8. Navigate to the Select widget and click the Actions button that appear next to each layer.
  9. Select Statistics from the drop-down menu. The data action window of the Statistics action is displayed.
  10. Select the desired numeric field in the drop-down menu.
The image below shows all other numeric fields are displayed in the Statistics data action from the Select widget.
All other numeric fields are displayed in the Statistics data action from the Select widget.
Article ID: 000033329
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
