PROBLEM
Numeric field values of a CSV file are displayed in scientific notation in ArcGIS Pro
Last Published: January 28, 2022
In ArcGIS Pro, members can view Microsoft Excel data by adding CSV files as non-editable stand-alone tables. Refer to ArcGIS Blog: Work with Microsoft Excel and CSV files in ArcGIS Pro for more information. Sometimes, adding a CSV file to ArcGIS Pro displays the numeric field values in scientific notation, as shown in the image below.
The numeric field values display as scientific notations in ArcGIS Pro.
Cause
  • The numeric field values in the attribute table exceed the data type precision limit.
  • The numeric field values exceed 11 digits in Microsoft Excel.
Solution or Workaround
Depending on the cause, use one of the following workarounds to display the numeric field values accurately in ArcGIS Pro.
Use a custom number format in ArcGIS Pro
In ArcGIS Pro, use a custom number format to display the scientific notation as custom numeric format strings. Refer to How To: Change numbers in scientific notation to a custom numeric format string in ArcGIS Pro for steps and more information.
Export the CSV file as a geodatabase table, and convert the numeric field to a text field
In ArcGIS Pro, export the CSV file as a geodatabase table and convert the scientific notation to numeric values in a new text field.
  1. In ArcGIS Pro, export the CSV file as a geodatabase table.
  2. Click the Analysis ribbon and click Tools.
  3. Search for and select the Calculate Field (Data Management Tools) tool via the Find Tools search box.
  4. In the Calculate Field pane, select the geodatabase table created in Step 1 from the Input Table drop-down list.
  5. Specify a field name for Field Name.
  6. Select Text from the Field Type drop-down list and double-click the field containing the scientific notation data from the Fields list.
  7. Click Run.
Change the field's cell format in Microsoft Excel before importing the CSV file to ArcGIS Pro
Keep the Microsoft Excel file open throughout the workaround. Closing Microsoft Excel converts the field values back to scientific notation.
In Microsoft Excel, change the field's cell format to Number and add the CSV file to ArcGIS Pro. Refer to Microsoft: Available number formats in Excel for more information.
The field displays the accurate values in the attribute table after a custom number format is used in ArcGIS Pro, as shown in the image below.
Th field displaying the accurate values in the attribute table.
Article ID: 000026985
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
