PROBLEM
Numbers don't display properly when map configuration files are edited manually
I manually edited my map configuration file and now numbers don't display in their entirety. For example, "1,850,000" shows as just "1".
Cause
ArcIMS doesn't support separators, such as commas, in numbers.
Solution or Workaround
Do not use decimal separators in numbers. For example, use "1850000" instead of "1,850,000".
    Article ID:000004443
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
