PROBLEM
In ArcGIS Pro, applying a definition query to exclude specific values from a field removes records with null values. This issue results in the loss of data intended for analysis or visualization. For example, excluding records with the value 'Public' from the TYPE field, which contains the values 'Public', 'Private', and null, also removes records with null values from the attribute table, as shown in the image below.
This is expected behavior when filtering records with null values, which indicate the absence of data and cannot be defined by any specific value. Because null values are unknown, they cannot be selected using equality comparisons. Therefore, when creating a definition query to exclude certain values, records with null values are also filtered out, as they do not meet the query criteria.
To address null values, use the IS NULL or IS NOT NULL operator in the definition query. Refer to ArcGIS Pro: Common expressions: Searching for NULL values for more information. In this example, to return records with null values in the query results, modify the query expression to include null values using the IS NULL operator.
Note: Alternatively, on the ribbon, click the Data tab. In the Definition Query group, click Build Definition Query.
Note: The query builder opens in Clause mode by default. To open it in SQL mode, toggle the SQL option.
Add the following expression to the existing query and replace <field> with the required field.
Or <field> IS NULL
The table shows the records with null values included when excluding records with 'Public' from the TYPE field in the definition query.
Article ID: 000033941
Get help from ArcGIS experts
Start chatting now
