PROBLEM
The Tin to Grid tool closes without an error immediately after clicking OK and does not produce any output.
This tool uses the ArcInfo Workstation TINLATTICE command, which is part of the TIN extension. The tool does not check if the extension has actually been installed. If the TIN extension is not installed, the tool simply closes.
Article ID:000003098
Get help from ArcGIS experts
Download the Esri Support App
