PROBLEM
Newly added fields not displayed in the ArcGIS Experience Builder Table widget
First Published: January 2, 2026
Last Published: March 3, 2026
Newly added fields in the feature layer are not visible in the ArcGIS Experience Builder Table widget even though the fields are visible in Map Viewer, as shown in the tables below.
In Map Viewer:
The fields are visible in Map Viewer
In the Table widget:
Some fields are hidden in the Table widget in Experience Builder
Cause
The Table widget is configured with a customized table schema. Any additional fields added to the source layer after configuration are not automatically reflected in the existing Table widget.
Solution or Workaround
Unhide the fields in the Table widget
  1. In Experience Builder, open the experience.
  2. On the builder toolbar, click Live view to switch to preview mode.
  3. On the Table widget, click the Show/hide columns icon.
  4. From the drop-down list, select the fields. The selected fields appear in the table, as shown below.
The drop-down list containing shown and hidden fields for the Table widget
Update the customized Table widget fields
  1. Open the Experience Builder web experience.
  2. On the canvas, click the Table widget to open the Table panel.
  3. In the Table panel, click the existing data source.
  4. In the Sheet configuration panel, under Field, ensure the Visible button is enabled for the fields.
  1. Save, preview, and publish the experience.
The Table widget below displays the newly added fields.
All fields are now visible in the Table widget
Article ID: 000039828
Software:
  • ArcGIS Online
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
