PROBLEM
New layer's 3D property tabs are not visible in ArcCatalog
Cannot see the 3D property tabs (Base Height, Extrusion, Rendering) for a new layer in ArcCatalog.
Cause
ArcCatalog shows the default (2D) layer property tabs for layer files unless 3D properties have been set for the layer, or unless you 3D-preview the layer in ArcCatalog.
Solution or Workaround
  1. Click the layer in the Catalog tree.
  2. Click the Preview Tab.
  3. Click the Preview dropdown list and click 3D View.
  4. Right-click the layer and click Properties.
    The 3D Analyst Extension must be enabled in ArcCatalog before you can set 3D properties of a layer.
Article ID:000004190
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
