PROBLEM
Network IO error
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
** Fixed at ArcGIS 8.2 **This error occurs when clicking zoom to selected extent button for a database theme:"Network IO error"The connection to SDE is consequently broken.
Cause
This is a known problem with Oracle SDE layers stored as Oracle spatial data objects (SDO) and SDE 8.1 (Database Access 2.1c).
Solution or Workaround
Use SDE layers stored as ArcSDE compressed binary layers.
Article ID:000004986
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
