PROBLEM
Network Analyst: Cannot get directions after opening a map document
It is not possible to generate directions from a route or closest facility layer from an opened map document until solve has been executed.
Cause
In order to minimize the size of map documents, network analysis layers do not store the analysis results; only the geometry is stored. As a result, the analysis layer must be re-solved after opening the map document to have the traversal information needed to generate directions.
Solution or Workaround
To generate directions after opening a map document with an analysis layer, follow the steps below:
  1. Start ArcMap.
  2. Open the map document.
  3. Select the analysis layer you want to get directions.
  4. Click the Solve button in the Network Analyst tool bar to solve the route again.
  5. Click the Directions Window button to generate and display directions.
Article ID:000007832
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
