PROBLEM
Network analysis tracing task will not print results
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
The network analysis tracing task in geometric network of ArcMap 8.02, displays correctly on screen, but print preview and print do not produce accurate results.
Cause
This is a known problem.
Solution or Workaround
There is no workaround in ArcMap 8.02. This issue is addressed in ArcGIS 8.1.
Upgrade to ArcGIS 8.1.
    Article ID:000003883
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
