PROBLEM
Neither the Append nor Merge tools respect the schemas of the input feature classes and create duplicate fields
After running the Append or Merge tools, the feature class schemas are not respected, and fields are duplicated.
Cause
The input feature class fields have spaces or special characters in the field name(s).
When the Append and Merge tools try to match fields by name, they search the existing fields for the same name. If the name is not found, the tool creates a new field. When it creates the new field, spaces and special characters (-, *, /, &, etc.) are replaced with underscores (_).
When the field from the second or third feature class is compared to the existing fields, the names are no longer the same, so a new field is created.
For example, if a field is called 'Modified?' in both tables, the first table's field is added as 'Modified_'. When the field from the second table is compared the this field, a match is not found. A new field is created, called 'Modified_2'.
Solution or Workaround
Remove spaces and special characters from field names. See the link in the Related Information section below.
    Article ID:000009315
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
