PROBLEM
Moving a vertex in the Edit Sketch may not rubberband properly
When moving a vertex in the edit sketch, the line that rubberbands between adjacent points in the sketch may not appear, even though the vertex location is updated.
Cause
When a part of the edit sketch falls outside the map display, the rubberbanding between connected vertices is not dynamically updated.
Solution or Workaround
Zoom out until the entire edit sketch is visible in the map display.
Article ID:000004263
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
