PROBLEM
'Model shadows' option on Hillshade dialog box should be disabled when input is a TIN
TIN's don't support modeling of cast shadows, so even though the option is enabled, using it does nothing.
Cause
This is a known issue.
Solution or Workaround
  1. Convert the TIN to a raster via the 'TIN to Raster conversion' tool found on the 3D Toolbar.
  2. Use the resulting raster surface as input to the Hillshade dialog.
Article ID:000003377
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
