PROBLEM
If the street data is updated and an address is being geocoded using the geocoding dialog, candidate postal codes are not shown. Standard address and intersection geocoding candidates continue to work as before.The postal code centroid candidate is found at the bottom of the candidate list and is marked by a solid pink dot in the score column.
Incorrect formatting of the Zip field is the cause. The format of the Zip field on the street data update is double when it should be data type of 5 text characters.
Article ID:000008486
Get help from ArcGIS experts
Download the Esri Support App
