PROBLEM
After importing a Keyhole Markup Language (KML) file into ArcGIS Pro, certain features are not displayed on the map, even though the features are present in the KML file. Missing features include points, lines, polygons, or other spatial data that are visible when viewed in Google Earth Pro or ArcGIS Online Map Viewer.
The map below shows the original features displayed after importing the KML file into Google Earth Pro.
The map below shows only some features displayed after importing the KML file into ArcGIS Pro.
Depending on the cause, the workarounds described below are applicable.
To separate the multipart features into singlepart features, use the Multipart To Singlepart tool in ArcGIS Pro.
Note: The Smooth Polygon tool is available with Standard and Advanced ArcGIS Pro licenses.
The Smooth Polygon tool reduces sharp angles in polygon outlines, improving visual appeal and cartographic accuracy.
Re-export the KML file as a new file using the original application used to generate the KML file.
Alternatively, export the layer as a KMZ file instead. KMZ is a compressed version of KML, reducing file size and making it more efficient to store, share, and manage large datasets. Its compression, bundling, and portability make KMZ a practical option for workflows in ArcGIS Pro, especially when working with complex datasets.
The map below shows the features correctly displayed after importing the KML file into ArcGIS Pro.
Article ID: 000034361
Get help from ArcGIS experts
Start chatting now
