PROBLEM
Missing ESRIDefaultMarker font in Adobe Illustrator
Last Published: May 4, 2020
When exporting a map document to a .ai file, opening the file in Adobe Illustrator returns the following error:
Error:
The document uses fonts that are currently not available on your computer.
Image of error message
Cause
The following are known causes for the error:
  • The ESRIDefaultMarker font is not installed on the machine.
  • Adobe Illustrator does not detect the ESRIDefaultMarker font. This can occur if the font is installed with a different version number.
Solution or Workaround
Use the following solutions depending on the cause of the error:
Follow the steps below to install the font.
  1. With Windows Explorer, navigate to C:\Windows\Fonts.
  2. Right-click the font file or folder (usually named Esri_<version number>.tff).
  3. Click Install.
  4. After installation is complete, restart the machine.
  1. Open the .ai file in Adobe Illustrator.
  2. Navigate to Type > Find Font.
  3. In the Replace with Font From section, select the missing ESRIDefaultMarker font from the Fonts in System list.
  4. Click Done.
Article ID: 000016666
Software:
  • ArcMap
  • Third Party Product
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
