PROBLEM
Missing Display tab for image catalog layers in ArcScene
Unable to set the resampling method because the Display tab for the image catalog layer properties dialog does not show up in ArcScene.
Cause
This is a known issue with ArcGIS 8.1.
Solution or Workaround
This problem is addressed in ArcGIS 8.1 Service Pack 1. See Related Information section to download this pack.
If you have not installed Service Pack 1, you can set the Display tab properties in ArcMap, save the layer, and use the saved layer in ArcScene.
Article ID:000003745
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
