PROBLEM
Mensuration tools are disabled in ArcGIS Pro
Last Published: October 24, 2023
In ArcGIS Pro, the mensuration tools are used to measure ground features in imagery. In some instances, when working with an elevation raster, the mensuration tools in the Mensuration group are disabled.
The Mensuration group on the Imagery tab in ArcGIS Pro.
Cause
  • The elevation layer is placed in a scene view.
  • The elevation layer is not selected.
  • The raster type is not compatible with certain mensuration tools.
  • The Image Analyst license is not assigned to the user.
Solution or Workaround
Move the layer to a map view
Add the ground elevation surface layer to a map. Refer to ArcGIS Pro: Work with the Ground elevation surface layer for further instructions.
Alternatively, to convert the layer from a scene view to a map view, click the View tab on the top ribbon and in the View group, click Convert > To Map.
Select the elevation layer
In the Contents pane of the ArcGIS Pro project, select the elevation layer. The layer is highlighted once it is selected.
Use a compatible raster type
Certain mensuration tools are only available depending on the raster type. This can be determined by examining the information stored in the metadata of the raster. Refer to ArcGIS Pro: More about image mensuration for more information.
Assign an Image Analyst license to the account
Depending on the license type, authorize an Image Analyst extension to the ArcGIS Pro account. Refer to ArcGIS Pro: Authorize extension licenses for further instructions.
Upgrade ArcGIS Pro
Upgrade to the latest version of ArcGIS Pro. Refer to ArcGIS Pro: Update ArcGIS Pro for further instructions.
The image below shows the mensuration tools enabled in ArcGIS Pro.
The Imagery tab in ArcGIS Pro.
Article ID: 000031139
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
