PROBLEM
If the dataset used is of type image, then the resources consumed can be considerable, owing to the use of Java Advanced Imaging, which maintains a separate cache of imagery.
If the dataset is of type shapefile, the the resources consumed include an in-memory cache of features, which is limited by a memory parameter specified in the resource property file named cache.properties. Note that if you modify the cache size specified there, then it is possible to negatively affect display performance of shapefiles as a result.
Article ID:000004435
Get help from ArcGIS experts
Download the Esri Support App
